Difference between DMC Pro and Rip DVD Plus
PeterL
Posted : Friday, April 9, 2010 5:41:14 PM(UTC)
I bought Digital Media Converter Pro a few months - which has been working great.
I see you have some new software. What are the advantages of using RIP DVD Plus?
Posted : Tuesday, April 13, 2010 6:39:25 PM(UTC)
Rip DVD Plus is specifically designed for ripping DVD's. With Rip DVD Plus can rip individual titles and chapters or rip the entire disc. To merge the ripped sections, select the checkbox 'Merge to a single file'. Ripping with subtitles is supported, and you can also apply effects to adjust brightness, contrast, and audio volume.
A full overview of Rip DVD Plus is available here. Or download a free evaluation version and try it out.
