Connecting USB cameras to a PCIe USB 3.0 interface card
CurtisZM
Posted : Wednesday, August 26, 2015 10:53:39 AM(UTC)
I am not able to use a external USB hub. I would like to know if I can connect my USB camera to an internal 4 port PCIe USB 3.0 interface card?
Posted : Wednesday, August 26, 2015 2:58:13 PM(UTC)
Yes, WebCam Monitor supports most types of USB interfaces. You can connect up to 4 USB cameras per PC. Your 4 port PCIe USB interface should work just fine.
After your camera is connected, you may find this article on getting started with WebCam Monitor helpful:
http://www.deskshare.com/resources/articles/wcm_QuicklySetupSecurity.aspx
