Rank: Member
In addition to a microphone to pick up audio which would turn on the webcam, can I additionally (or instead) use a motion sensor to turn on the webcam? If so then how is this possible?
Thanks, Walter
Security Monitor Pro (and WebCam Monitor) both have built-in motion detection. You can set up motion-triggered alerts to start recording in seconds using the Configuration Wizard.
