Wifi to PC connection problem in Screen Cast
harshhass
Posted : Thursday, February 8, 2018 6:49:17 PM(UTC)
I have the Screen Cast app running on my phone and I want to view it from my PC. I am pretty sure my phone and PC are on the same wifi network, but I am not able to connect. Can you help me?
Posted : Friday, February 9, 2018 12:01:56 AM(UTC)
Even when you are on the same network it is possible that you will not be able to view your mobile screen from your PC. This can happen because of problems with firewalls, or other network configuration. An alternative is to try connecting using mobile hotspot. This will bypass your network completely because it is a direct connection from your PC to your mobile device.
On your mobile device, turn on the mobile hotspot from Android Settings. Go to Screen Cast and select Settings >> Connection Type >> Mobile hotspot. Note the URL and password to connect.
On your PC, turn on Wi-Fi and view the Wi-Fi network list. Select the hotspot created by your device and click Connect.
Now open a browser on your PC and enter the URL from your mobile device. You will now see your mobile screen in the browser.
