Welcome Guest Search | Log In
A feasible process using DMC for NTSC-DVD to PAL-DVD conversion
kcrea
Posted : Monday, April 23, 2007 9:37:58 AM
Rank: Member
Was thanked: 0 time(s) in 0 post(s)
Hello Folks:
I am evaluating DMC to see if it will do what I need; which is the following:
I have DVDs I create in Avid Liquid that produce VOBs on my local hard-drive as well burn directly to DVD. The DVDs are created in NTSC format and I need to create DVD versions in PAL for viewers overseas, etc. So, ... my plan was to take the VOBs that were created in the directory VIDEO_TS (on my hard-drive) and convert them to PAL using DMC, and then burn them to DVD using Nero.
A typical VIDEO_TS folder will contain the following files:
VIDEO_TS.BUP
VIDEO_TS.IFO
VIDEO_TS.VOB
VTS_01_0.BUP
VTS_01_0.IFO
VTS_01_1.VOB
VTS_01_2.VOB
VTS_01_3.VOB
My plan was to create duplicate directory structure as above with VIDEO_TS on the root; except the VOBs will now be PAL instead of NTSC. Then I was going to burn the directory structure "VIDEO_TS" and everything under it to DVD.
Now, my questions are:
1) Does this seem like a feasible and consistent process?
2) After conversion, I noticed that the file extension is mpg as in "VTS_01_1.mpg" versus "VTS_01_1.VOB" Can I just change the extension after conversion?
3) Considering this scenario, do I need to burn via Nero as a "Data DVD" or "Video DVD?"
4) The other files under the VIDEO_TS directory don't have to be changed in anyway - right?
5) Are there any gotchas I may not be aware of?
Thanks in advance for your patience and help!
Kevin
Posted : Monday, April 23, 2007 11:05:24 AM
Was thanked: 25 time(s) in 21 post(s)
Digital Media Converter can convert your video from NTSC to PAL format.
Our recommended procedure for creating PAL DVDs would be:
1. Convert the VOB files to PAL MPEG 2 files (.mpg extension) as you have already done.
2. Use your own DVD burning program to create a new DVD using the Video DVD in PAL format.
The program will create new BUP and IFO files which will match the video files.
Users browsing this topic
Guest
