How much free drive space is required to monitor and record from IP cameras?
MextDildMeelp
Posted : Tuesday, June 28, 2011 5:07:01 AM(UTC)
How much drive space is required to monitor and record from 3 IP cameras?
I have 300gb available on my external drive and it tells me there is not enough space and recording will stop. I am not sure why this is happening it was working fine for a month. The files that were recorded earlier are only around 20MB.
Posted : Wednesday, June 29, 2011 11:34:26 PM(UTC)
There are two settings related to drive space in Security Monitor Pro - the temporary working drive and the recordings drive. It sounds like you are using the default settings.
Make sure the temporary drive has adequate storage space, a minimum of 1GB is required. You can check the 'Temporary Working Folder' you are using by clicking Tools >> Application Settings >> Advanced. If drive is full, click on the Browse button to select a drive and folder that has more space. See this page for an illustrated example of selecting the temporary folder.
